I have finally began the plunge into a 250 quad build and will need a lot of help from this great community. I purchased a Hubsan X4 and have a blast bashing the thing around the house at my wife's dismay. Our apartment is pretty small (600sq ft). Thankfully is hasn't ended up in her hair yet like many have warned and she has given me her blessing on building this quad.
Now that the weather is cold out, it is build season!
Goals for the build:
Get me familiar with components, building, tuning, and flying line of sight. And dive into the FPV world with this platform once I become proficient and the funds become available. I might also bump up to 4S setup in the future.
I would like quad to be serviceable as much as possible without the use of a soldering iron. I have access to one and know how to use it, it just more of a convenience thing.
Share the knowledge of building a quad with others who would also like to start from scratch.
Current Components:
SunnySky X2204 2300Kv motors $22.80 EA
Velotech Magic 12A ESC with 1A BEC $Came Free with motors
ZMR250 Composite Carbon Fiber Frame $24.95
Massive32 Flight Controller Pre-soldered $31.95
The Squid Quad Breakout cable 3.5mm bullet to XT60 $10.99
Naze 32 - RC Breakout Cable for RX $2.99
RMRC 5A UBEC $9.99
2mm Bullet Connections for between Motor/ESC $3.66
3.5mm Bullet Connections for between ESC/Battery $3.98
5x3 GemFan Props $3.00/set
1300mAh 3S w/ XT60 connector $~10-15
Turnigy 9x w/ HK T6A RX
Battery Straps
Nylon standoffs for FCB
M5 lock nuts
Need Components:
I believe I have everything on order
Future Upgrades/Components:
F-12A-HV Fire Red series High Voltage OPTO (2-4 Cells) SimonK-(RapidESC)
ImmersionRC 5.8GHz 600mw Audio / Video Transmitter
ImmersionRC 5.8 GHz SpiroNET Antenna Set RHCP (SMA Connector)
FatShark Goggles
Mobius
My Initial Thoughts:
I bought 5 motors and ESCs to start. The Velotech ESCs came free with the motors, so I'll give them a try and see what happens.
Looking Back:
One ESC stopped working properly so I had to swap it out. I'm glad I bought a spare. I think I got to much "snow" under the heatshrink and killed it.
While out flying I noticed that while in acro mode the red light would flicker on the board and it would auto level. I pulled the board and checked all the connections and found that the AUX1 pin (3 position switch defining flight modes) was not properly seated into the plastic housing and caused an intermittent signal. This caused the board to default to horizon mode. After putting it back together, it was back to operating normally.
-Blake (Offaxis)
Current Components:
RMRC 5A UBEC $9.99
Battery Straps
M5 lock nuts
Need Components:
FatShark Goggles
Mobius
Looking Back:
-Blake (Offaxis)
