Type
FT Flerken Printed Parts
3D Modeled By: Dan Sponholz​
If you're building the FT Flerken from the purchased plans available from the FTCA, you can print these STL files to help you complete your build.
Don't have a printer? No Problem. You can order the plywood parts from the Flite Test Store here:
FT Flerken Short Kit
Or save even more time and order the speed build kit here: FT Flerken
FT Flerken 3D Parts.zip file contains:
Hatch Part A
Flerken_A.stl
Hatch Part B
Flerken_B.stl
Hatch Part C
Flerken_C.stl
Battery Tray
Flerken_BT.stl
Firewall
Flerken_FW.stl
Control Horn
Flerken_CH.stl
Print Setting and Notes
FT Flerken 3D Parts.txt
Test Print settings (All Parts):
Printer:
Creality CR-20 Pro
Material:
PLA+ (eSun)
Layer Height:
0.20 mm
Supports:
None
Raft:
No
Infill:
15%
Note:
Watch the first layer height and make sure it's not too flat. Elephant's foot will cause an issue with fit for the latch parts.
Author
flitetest
Downloads
1,400
Views
2,676
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from flitetest
Latest reviews
This will be a great addition to he kit. Thanks for sharing.
