1:21 Scale Boeing B-29 Foam Board Build
AeroEngineer20
Hello all! A while ago, I built a 44" B-29 using Emax 1806 motors with 5x4 props on it. I was a more inexperienced builder and pilot at the time, so I didn't design the spar to be sturdy enough for its speed and wing loading. However, I crashed due to losing orientation long before the spar folded. Whoops.
Before the crash
So, after my later failed attempt at an F-104 with landing gear, I learned more about how I should design aircraft landing gear to be sturdier. Since I have more 3D printer filament than money for retractable landing gear, I decided to give it another go, this time on a larger B-29. I'm making it at this scale since it nicely fits 9" propellers on the four motors I have.
So far, I have designed both the nose and main landing gear systems, and have a rough idea of the rest of the structure. I'm planning on flying it with a Pixhawk controller for an autopilot/system that will limit the speed at which I crash into the ground. This is a work-in-progress, so I'll be posting updates somewhat periodically. I'll be happy to answer any questions you may have.
For now, enjoy the pictures!
Fancy render of the progress as of now.
Nose Assembly - It will be removable to change batteries
Nose gear, extended and retracted
Main gear, extended and retracted
Wide view
Flying Farm Kid
Any update on this?
Before the crash
Wide view
Any updates or progress on this?
