BlockerAviation
A few months ago I embarked on this journey of building the biggest balsa kit I have ever built! This kit is the 109" Hostetler's Aeronca Champ that I got from a fellow club member a while back. The fuselage and tail are all framed up and I just started on the wing last week! I plan on making an update once a week for the thread doesn't get too boring. Anyways I'm really excited to get this thing flying, in fact I've already picked out the color scheme!
Here's the scheme I've chosen!
So today I'll start off by wrapping up the last couple of months of this build and start the weekly posts this weekend. Like I said before, I have the tail and fuse framed up and the wing started. The tail feathers are fairly simple, they build just like most of the ones I've done already. The plans call for using two servos on the elevator but I think that's overkill so I plan on using one servo inside the airplane to save weight and make the over all look of the airplane neater. I'll also be redesigning the rudder servo placement to also make the airframe neater as well. Although the fuselage looks done there is still a lot of work to do. The bottom formers need to be made and installed and the firewall needs to be drilled for my 20cc evolution and installed too. There is also the wing mounting plates that needs to be cut, but I have to finish the wing before I do that.
(Ignore the green on the tail, it was a test piece for another airplane).
Now on to the wing. I had a little trouble with the spar length so I had to do a bit of splicing to get the length I needed. There was also the issue with the servo placement again, namely, I can not stand having servos sticking out of my scale aircraft if I can help it. So I built a tray to mount the servo sideways like how they do in the arfs and other kits. I'm also changing the way the leading edge is done (more on this in next weeks post) and the way the sheer webbing is installed. Over all the way the wing is built is not very clear, so I've kind of had to make it up as I go (keep in mind there is no manual for this airplane) but this has allowed me to make changes to the airplane that really make it my own.
From this,
to this,
Let me wrap this first post up by saying, this airplane is challenging my ability's as a builder, and if you ever get a chance to build a balsa airplane, TAKE IT! You wont regret it! This is going to be my fourth (large) balsa kit I've built and it hasn't gotten old yet seeing an airplane go from a box of sticks to a flying masterpiece.
From this,
to this,
