You need to get all up weight sorted first, as a 1200kv on a lower stator size will perform very differently to a 1200kv with a taller stator.
1200kv could be too fast for 10” props, depending on the weight being lifted and the prop profile, especially with a flatter can motor where all the power is higher up the RPM range.
Kv is a secondary consideration, motor size and thrust at the desired voltage is the starting point, all that is usually in the motor data sheets.
If you tell us the specific aim of this build and it’s weight then we can probably dial you into a set of motors for it.
