Well no work today because of the weather so I plugged away at the wing a bit. All glued together other then the winglets. I did cut out balsa winglets, we will see how they sand out to match the the contour of the wing, worse comes to worse they will be foam
. Glued in filler foam in certain areas so when I sand the le & te plus to match the contour of the airfoil it should all be smooth for when the skin goes on. The wing is tapered from the root chord to the tip .
