Hi guys, I've flown a few blade helis and quads but now I want to build my own H with a flite test frame.
I've been reading around the web for a few configurations and I wanted to try something like this:
http://ecalc.ch/xcoptercalc.htm?ecalc&lang=en&cooling=2.5&rotornumber=4&weight=225&calc=sum&elevation=500&airtemp=25&qnh=1013&batteries=lipo_2500mah_-_35/50c&chargestate=0&s=4&p=1&esc=max_20a&motor=turnigy&type=35|ntm2836-750&gear=1&propeller=0&propconst=1.3&proptwist=0&diameter=11&pitch=4.7&blades=2
Now the maddening thing is I can't get eCalc to build a config with long flight times, switching the 11inch props to 8's increases flight time but reduces hover time??? Seems like I'm doing something wrong with the tool or I don't understand motor/prop/battery relations :black_eyed:
Cheers
Tentative HK parts list:
Quantity Stock Product description Price Weight
3 T2450.4S.30 - Turnigy 2450mAh 4S 30C Lipo Pack $71.97
5 NTM2836-750 - NTM Prop Drive 28-36 750KV / 265W $79.95
4 017000055 - 8045 SF Props 2pc CW 2 pc CCW Rotation $11.16
4 017000054 - 8045 SF Props 2pc CW 2 pc CCW Rotation (.. $11.16
1 DL-Volt-Alarm - On Board Lipoly Low Voltage Alarm (2s~4s.. $2.15
1 258000011 - 10CM Male to Male Servo Lead (JR) 26AWG .. $4.75
4 9192000130-0 - Afro Slim 20Amp Multi-rotor Motor Speed .. $54.32
1 015000095 - XT60 to 4 X 3.5mm bullet Multistar ESC P.. $3.36
1 9171000202 - OrangeRx DSMX3 Spektrum Compatible DSMX .. $19.25
1 Prop-Bal - Turnigy Magnetic Precision Prop Balancer $12.95
4 NTM28-ACC - NTM Prop Drive 28 Series Accessory Pack $7.40
2 9171000015 - 5.6mm x 14mm M3 Nylon Threaded Spacer (1.. $3.76
2 OR009-00504 - M3x12mm Nylon Screws (10pcs/bag) $1.86
2 Turnigy-HKLP - Turnigy Battery Strap 330mm $3.18
1 9171000334-0 - Hobbyking KK2.1 Multi-rotor LCD Flight C.. $29.99
2 OR009-01502 - M3 Nylon Nut (10pcs/bag) $1.38
*I do own a dx6i and multiple cell charger
Cheers
