Awesome!!Just started my attempt at this. Thanks @Grifflyer for the work and plans for this great looking model! My first foam board build, let's see how it goes.
Done preparing the fuselage parts, gonna start gluing next. I was planning to make some sort of GPS enabled FPV version of it, hopefully it won't end up weighting too much.
I embedded some small carbon fiber rods in little bits of foam to the outside of the elevator and ailerons as they are very fragile. Your build is coming on great!Did some assembly last night, and I'm quite happy with the results so far! Everything fits pretty well even though I did sometimes do some sloppy cutting.
I think the only thing I really messed up so far a bit is the EDF, as I realized that the cables should probably be pointing downwards instead of up to let them run through somewhere. I figured that trying to fix it now would just break the structures, so I ended up carving a small opening for the cables to pass above the mount and the doubler.
Hoping to finish the fuselage tonight as much as I can, and then move on to the wings.
Thanks for the tip! I have some 6mm tubes, although they are kinda too thick and reserved for another project. Need to evaluate the situation later🤔I embedded some small carbon fiber rods in little bits of foam to the outside of the elevator and ailerons as they are very fragile. Your build is coming on great!
It's looking great!! Running the cables like that is totally fine.Did some assembly last night, and I'm quite happy with the results so far! Everything fits pretty well even though I did sometimes do some sloppy cutting.
Slow day but making progress. One of the good things about using slower glues is that it forces you to slow down and enjoy the build. Those of us older builders who remember Ambroid and Duco will appreciate that. If you don't like the ugly brown glue lines you could use yellow (Titebond II or Traditional) or white glue (Elmers) but the Titebond III has very good open time.
My helper is telling me its time to quit for the day... Until tomorrow, everyone please stay safe!!!
View attachment 163236 View attachment 163233 View attachment 163237 View attachment 163235 View attachment 163234 View attachment 163238 View attachment 163241
This got me curious about the weight of mine. I can’t say I was super carful to keep the weight down while building. Thick poster board thrust tube. 1.2mn push rods, 12g 3d printed wing tips, 4 small magnets for the canopy, etc.....A quick check on the weight prior to painting shows it being 339.0g (11.96oz), flying weight is 465.0g (16.40oz) with a 3S 1550mAh battery.
Mine is 554gm ready to fly 4S 1300MAh battery, it flys great!!!This got me curious about the weight of mine. I can’t say I was super carful to keep the weight down while building. Thick poster board thrust tube. 1.2mn push rods, 12g 3d printed wing tips, 4 small magnets for the canopy, etc.....
375g without battery. 539g ready to fly with a RDQ 1300mah 100c 4s.
If, no when I crash this one and rebuild. I think I’ll use a few of the things you did on your build and see about dropping a few grams.
Nice build. It looks great.
The difference is I didn’t paint mine I guess. Just a little color tape. And I agree they fly great.Mine is 554gm ready to fly 4S 1300MAh battery, it flys great!!!
very nice build , Since I have tons of time at home i would like to build one.
is there anyone who can help me to find a pdf file so I can move parts in the plan to save some space in plan and paper that i am going to print on. the file on the first page does not allow me to edit anything on adobe acrobat that I use to edit all my flitetest plans.
