Airwolf
I have a problem.
FC (HK KK V2) is flashed with the latest Tricopter firmware, and I can arm it without problems, but left and right motor won't run when throttle is applied. Instead they're buzzing and beeping (just like when one of the wires is disconnected or like it would be jammed by something). Of course electrical connections are OK, ESCs are OK (throttle position is set), and motors spin freely. Also yaw servo doesn't work (it has a signal and power but it won't move). Tail motor runs OK. Rx-FC-ESCs are connected OK I think (Rx Ch1 (Ailerons in Tx) is connected to AILE port on FC, Rx Ch2 (Elevator in Tx) is connected to ELEV port on FC, Rx Ch3 (Throttle in Tx) is connected to THRO port on FC and Rx Ch4 (Rudder in Tx) is connected to RUDD port on FC).
Tx mixers etc are turned off (and Tx it's in acro mode). Any ideas what can be wrong?
