Hi there all, I am new here and just getting back into the hobby. I am planning on building the FT Sparrow Twin for my first FT build and I am trying to cram differential thrust into a 4 channel Rx (Radiomaster R84). I know that typically the solution for 6ch Rx's would be to have the ESC's just on a separate channel and also use the ESC's built-in BEC. The ESC I selected has no BEC AND I want differential thrust for the sweet sweet flat spins and shenanigans on a 4ch Rx. I have drawn up a solution and need the rubber duck test since I am no electronics wiz.
I just want to "tap" the negative from the BEC to a negative from one of the servos.
Thank you in advance and I look forward to learning and maybe even flying with some of y'all!
See the upper right-hand corner and the negative lead from the BEC for what I am proposing. If that will just not work, then I will get a 6ch Rx, but the 4ch is what I have.
(Parts list for ref)
https://www.racedayquads.com/products/spedix-20a-esc-lite-dshot-600-blheli_s?variant=36300447431
https://www.racedayquads.com/produc...tal-gear-digital-servo?variant=39447772725361
https://www.racedayquads.com/produc...pwm-2-4ghz-rc-receiver?variant=32194640773233
