Burg
Never catch a multirotor
I was noticing many tricopter yaw mechanisms lately based on a helicopter main rotor grip. Made me wonder how I could make one myself without a lot of cutting and gluing. This is what I came up with and I want to share it with you because it works really well. Let me know what you think ! I used the following parts :
El cheapo 10x10mm pine wood stick
Motor :
http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=549&productname=
Any 28xx size between 700kv and 1000kv will do
Plus one extra motor mount
Main rotor grip :
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10129
Both the motor mounts fit PERFECTLY over the upper and lower 'spacers' on the blade grip (!)
The shaft requires a 6mm drill
Servo :
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=9814
or
http://www.hobbyking.com/hobbyking/store/__9815__Hitec_HS_81_Micro_Servo_2_6kg_16g_0_11sec. html
Servo can be installed better, this was just a test fit..
Servo arm :
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17514
Very solid and a perfect for to the Hitec servo's
Thread for the ball links is M3
Ball links :
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10164
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=12301
Screws, nuts and zip ties :
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=12316
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6368
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17570
Motor :
Main rotor grip :
Servo :
or
Servo arm :
Ball links :
