AircPirateNinsei
Foam Board and Filament Shugenja
STATUS: The maiden flight was successfully completed and the BETA-plan is published!
GENERAL SPECIFICATIONS
WINGSPAN: 800 mm | 31.50 in
CG: 45 mm | 1.77 in
LENGTH: 680 mm | 26.77 in
DRY WEIGHT: 304 g | 10.72 oz (TYPE S)
ALL UP WEIGHT: 390 g | 13.76 oz (TYPE S)
EXPO: 30 %
CHANNELS: 4 (THR | AIL | ELV | RUD)
RECOMMENDED SETUP - TYPE S (works wit FT Power Pack F):
MOTOR: 2300 kv (2205)
PROPELLER: 6x4
ESC: 20 A
SERVOS: 4 x 5 g
BATTERY: 1000 mAh 3s
RECOMMENDED SETUP - TYPE R:
PROPELLER: 6x4
ESC: 30 A
SERVOS: 4 x 9 g
BATTERY: 1300 mAh 4s
DOWNLOAD:
DOWNLOAD FREE BUILD PLAN
VIDEO:
PICTURES:
_______________
Old first post:
Inspired by nerdnics 800 series, I decided to build an Embraer EMB 314 Super Tucano - also known as ALX or A-29.
I designed this plane without PosterBoard, so it is an "easy to build" airplane. You need 2 sheets of FoamBoard.
You can also use your FT Mini Power Pod for this plane.
The BETA plan is almost ready!
CG: 45 mm | 1.77 in
EXPO: 30 %
PROPELLER: 6x4
ESC: 20 A
SERVOS: 4 x 5 g
PROPELLER: 6x4
ESC: 30 A
SERVOS: 4 x 9 g
DOWNLOAD:
VIDEO:
PICTURES:
_______________
Old first post:
