The maiden flight was successful and the Eazy is very easy to fly!
Unfortunately we havn't made a video.
Here is the link to the BETA-plan:
DOWNLOAD FREE DIY PLAN
Thank you all for the flowers!
At 4s you should reinforce the Wing Spar with a carbon tube (max. 5mm diameter).
Maybe you should do this already at 3s to avoid bending the wing.
@daxian
trojan js: Miner C infection? Luke Filewalker found … nothing!
Do you have the problem with only one file (which one) or all files?
Which AVG do you use? I will install and test it!
Which file do you want? I put the file in Google Drive and send you the link!
I am curious to see how your AVG will react to this!
STATUS: The maiden flight was successfully completed and the BETA-plan is published!
The AP Eazy is a Pusher Trainer that works with the FT Power Pack A or F. It has a FT Mini Power Pod.
If you want to build the Eazy with a 50mm EDF unit, you should check out the Eazy Ducted Fan!
SPECS:
WINGSPAN: 1000 mm | 39.37 in
DRY WEIGHT: 232 g | 8.18 oz
ALL UP WEIGHT: 335 g | 11.82 oz (with 3s 1250 mAh)
CHANNELS: 4 (THR | AIL | ELV | RUD)
DOWNLOAD:
DOWNLOAD FREE BUILD PLAN
PICTURES:
