speedbirdted
My stubbornness knows no bounds it seems. What do you do when Kinko's is snowed in and you can't be bothered to build one of the millions of other plans in your stash? You make your own!
I have drawn quite a few plans in my life but this is the first one I'm actually going to try to build. I feel my design ability has progressed far enough to allow this. However don't be at all surprised if this build is a lot rockier than some of my others as this is mostly uncharted territory for me. The building part I can do, but can I design something actually buildable?
The design choices are kind of like a cross between a Gee Bee Dreamer and a SlowPoke. I wanted the cartoonish bathtub kinda look to it. The name I didn't pick. Up until two days ago this airplane had no name; I was showing it around some club members and someone suggested I put in a doll as the pilot and then someone said "babydoll" so I guess that's it's name now. Some will shout at me for not even bothering to add a vertical and just a rudder, but: the fuselage design is such that the fuselage itself acts as the vertical. I have a large area behind the CG so theoretically it should be directionally stable.
I figured with Balsa 250 fast approaching I would also design something in that weight range. The span here is 21" and I didn't bother calculating the wing area but it's not much. I wanted a high wing loading, that will let it go faster
Being a small airplane means if I happen to have done everything wrong in terms of design and have created a conceptually unflyable airplane it won't be much of a waste of material if that's the case.
I have an unhealthy tendency to hoard Cox engines like you'd hoard water in a drought; so I might as well put one to use. I really wanted to use a TD 020 but sadly they're too expensive and I think an 010 wouldn't be enough power (and far too annoying!) so a Peewee 020 it is. My only concern with this is the integrated tanks on these things tend to give you about 30 seconds of engine runtime on a good day. Usually they run out of fuel before you can even get them tuned right. If it doesn't work well enough for my liking I might as well bypass it and add an external tank in the fuselage.
I started basic construction today too but I haven't got too much to show so far. The wing rib blanks (24 in total) are the three stacks of eight sheets of 1/16 balsa. The large 1/8x15/32 stick is the spar. I'm not sure why I weighed everything at this stage because so much crap is going to get shaved off. The wood is pretty much standard fare hardware store quality however they had a few nice 1/16 sheets in stock which I snapped up. I'm going to do a better job of materials selection here
Unfortunately this is kind of all I could do in terms of construction for today. Later I will print off some more wing rib templates to cut the ribs out...
I put in an order to Willy Nillies for a bunch of servos and hardware and related stuff the other day so I might as well take it slow until it gets here, no need to rush building if all the parts aren't even here yet. More to come...
