jpot1
Servos inside the fuse.
Put everything together and this is actually nose heavy without the battery. I only have a 75g 1100 kv motor which is the problem. I need to use a 1300 or 2200 mah 3s centered under the opening in the fuse top. Will have to see how this flies as I am not keen on taking the wing on and off to change the battery.
