I intended to build a KK 2.1.5 based VTOL first, but I got enthusiastic about the tricopter ;-)
Long story short, I just ordered the ElectroHub Y6 frame and some additional parts (including the tough tilt motor mount) and build Josh's 5 motor variant as mentioned in this article.
Setup will be as follows:
Controller: Naze32 full version
Receiver 1: Spektrum AR7700 (flight)
Receiver 2: Orange 6ch (gimbal control) X
Servo: EMAX ES3154 X
Power: Jeti SBEC
Power (gimbal): Pololu 12V Step-Up/Step-Down Voltage Regulator S18V20F12
ESC: 5x EMAX BLHeli Series 20A
Telemetry: Lemon LM0030 (volt, current, temperature and altitude)
Flight battery: Turnigy nano-tech 4500 mAh and 5000 mAh 3S 25~50C Lipo Packs
Motor: 5x EMAX MT2213 920KV
Prop: APC Slowfly 11x4.7, CW and CCW
Led strips: 2x Neopixel Flora RGB ws2812 LED strip X
Navigation lights: Dimensionengineering DELight Ultra Bright LED X
GPS: CRIUS NEO-6 V3.1 X
Bluetooth: HC-06 module X (to be replaced by a HM-10 module for iPhone / iPad usage)
Video tx: Boscam FT951 25 mW
Gimbal: HAKRC Storm32 3D gimbal
Camera: RunCam HD (X when charging)
Cleanflight 1.12.1 firmware
Cleanflight Configurator 1.2.1 (OSX)
Because I don't want all the current flowing through the Naze32, everything except for the board itself, marked with an X, will be powered through a modified pin header, connected to the second pair of wires from the Jeti SBEC. Scheme below.
On-board voltages:
- 12.6 - 10.5 Volt from lipo, feeds the ESC's, BEC and Pololu regulator
- 12 Volt from the Pololu regulator, to power the gimbal and video tx
- 5 Volt from BEC, standard on-board voltage for the X's
- 4.4 Volt, BEC voltage reduced by a diode, for the led strips and led's
To be continued...
Yvo
