Burnhard
Can‘t have enough spinners. Got excited.Spinners aplenty in that box. Have fun with the build.
Yours looks really great! Just a few questions on how you did the landing gear. Looking at the picture you placed the gear before the former, correct? Do the doors close and if yes, how did you make that?Just finished my Mossie. Not exactly museum quality but I think it will fly. Waiting for the snow to melt.
Mods: I made a clear canopy in anticipation of FPV. Added radiators on the leading edge which are functional as that is where the ESCs reside. Retracts are from an old Mosquito. Added steerable tail wheel and rudder.
If I were to do it over I would get some dense foam and carve items like the nose. Trying to shape foam board into compound curves is difficult and can never look as good as hand shaped foam or balsa blocks.
Thats very helpful! Nicely done. The landing gear looks pretty scale with the two legs.I made a small plywood reinforcement that I glued to the underside of that "U" shaped foam piece behind the motor. The gear is screwed to that. Gear legs are directly below the leading edge of the wing. This is an old-style retract with the servo at the back of the nacelle. You can see the push/pull rod in the photo. Barely visible is a short piece of fishing line connected to the upper part of the doors. The retracting gear engages this line and pulls the doors shut. This involves a little trial-and-error on the length and position of the fishing line. The servos are connected to different channels on the Taranis receiver so that I could adjust their throw.
One of the most beautiful airplanes ever made . . View attachment 222752
Still trying to figure out how to do a two leg landing gear as DIY.
Idea - View attachment 222819 If you are using servo-less retracts: The moving part on this type of retract system has setscrews that screw in to secure the gear leg. Remove the setscrews and add two machine screws and you now have a way to attach two gear legs.
Over the last weeks I finished the fuselage and the nacelles and I also prepared the vertical and horizontal stabilizer, canopy and lower wing skins.
On the landing gear I did a test fit with the dummy nacelle I created. I started with fitting the retracts after the former. That generally seems to work but there are a few things that I am not too happy about. First, with that setup the wheel sits pretty far back in the nacelle which means that the door needs to go pretty long way back. Also, when the retract is in landing mode, the wheel has only little space over the nacelle. I have therefore decided to move the retract further to the leading edge (like @Opus did for his one) before the former. It appears that my wheels are a bit too large (I was planning to use some 75mm wheels) so I will rather try something around 60-65 mm. For the leg for now I will use a single leg but will prepare the inner workings of the nacelle so that I can use a double leg later if I find a suitable solution.
Also made up my mind on the order how I will put things together. Once I am happy with the retracts in the nacelle, I will fix the nacelle to the lower wing skin. Then I plan to add a bit of carbon fibre to strengthen the wing. Next step will then be preparing the double flaps before closing the wing with the upper wing skins.
On the flaps I am thinking to make these move with one servo only which sits flush with the lower wing skin in the back of the nacelle and with the servo arm pointing inside the wing skin. That servo than links to a pushrod which connects to a carbon tube connecting both flaps. Will need to test that as well before putting pieces together.
I like the occasional challenge ;-). Just had a look at the seafury. Like the Idea with the two pushrods. Less complex than my T-connection. Still plan to put the pushrods inside the wing. Did that with my P51 as well.Looking good. And flaps too? Ambitious. The Fliteline Seafury has split flaps. One servo on each side with two pushrods off of each servo to the flaps. Works good.
This is actually a good piece of advice. You basically have two options, either a pull or a push configuration. Most models that I am aware of use a pull configuration where the control horn is pulled towards the servo. In my P51 (and also my Spitfire) I have used a push configuration where the control horn is pushed away from the servo. The benefit of the pull configuration is that it seems to imply less stress on the servo. The benefit of the push configuration is, that you can hide all pushrods and control horns in the wing. I am planning to use some Emax digital servos with a metal gear. Will check on the specifications to see how much margin I have with these.Food for thought: Of all the moving surfaces on an airplane, the flaps carry the biggest load. The servos that drop the flaps are under continuous strain as long as they are down. I have seen flap servos fail in flight because the pilot had flaps down and then was adding power and diving the plane. One side failed, creating an assymetrical situation instantly and a nasty UN-commanded roll. So, however you engineer your flaps, give the servos as much mechanical leverage as you can.
Double checked my servos. I will be using one Emax ES08MD II for the flaps on each side. These can carry a load of 1.6 to 2 KG. Hope that leaves enough margin.This is actually a good piece of advice. You basically have two options, either a pull or a push configuration. Most models that I am aware of use a pull configuration where the control horn is pulled towards the servo. In my P51 (and also my Spitfire) I have used a push configuration where the control horn is pushed away from the servo. The benefit of the pull configuration is that it seems to imply less stress on the servo. The benefit of the push configuration is, that you can hide all pushrods and control horns in the wing. I am planning to use some Emax digital servos with a metal gear. Will check on the specifications to see how much margin I have with these.
