cdfigueredo
How sure are that the sewn undercarriage will ot simply pull the plastic sheet away from the detachable bottom.
By comparison the nose gear is likely to be much stronger being mechanically clamped to a thick wooden bulkhead.
If the main gear was mechanically clamped to a solid wood detachable bottom then it would be as secure as the nose leg.
Are you suggesting I should build the detachable solid wood bottom? Balsa for example?
The problem is that where I live I can't get balsa wood or anything like that.
Any other solution?
