MikeJM
It is a modified Steve Schumate design. Changed from a 26" wingspan pusher prop to a 39" wingspan dual EDF.
I am doing foam composite construction (finish epoxy & 1/2 oz fiberglass cloth). It has dual 70mm EDFs, and thrust vectoring exhaust. At the moment I plan on mixing Ailerons with thrust vectoring, Elevator mix with thrust vectoring and Flaperons. I expect to weigh in less than 5 pounds, my EDF units produce 2.6lbs of thrust each.
Unfortunately I can't install retracts since we only have a rough grass field.
Here is a picture of my current progress: Bottom and top. I plan on glueing on 3mm depron over the wing ribs and then epoxy/ fiberglass cloth.
I have more pictures from the start to current.
Mike
Mike
