this is interesting. you have to make a trade between the power climb ability vs the ability to soar. one takes strength and mass power, the other light weight and big fragile wings.
Yeah but you gotta remove the slope from the equation. And - don't most of our planes have a WS greater than the length? 1:1 sounds pretty tight to me.
I do not plan on participating, but I think it's important to point out that nearly all airplanes which are not race planes have a longer wingspan than fuselage. Even the Mini scout has a 23" wingspan and is only about 19" long.
That's the twist, there is no limit on the cord tho. We decided that building a glider with a long wingspan and thermalling would be too easy so I added that rule.
just did a little math and figured that your right, it might be a little small, so I slightly changed the ws rule. This is the last change I will make to the rules.
Better, but that means of the 10 aircraft in my hangar, only 2 would be flyable in your competition based on this rule alone. Those two are a fantasy 20's racer and the Mini Scout.
Or you could build one for the challenge. I was hoping for this challenge to challenge the skills of the pilot and their building skills too. So far it's been challenging mine!
I would love to enter and my own design/build plane meets the length to span criteria but in a 10 second climb it would exceed the UK model plane height limit of 400' agl by more than twice!
I will however follow the results with interest.
