RodrigoDeLucca
Hey Guys,
I've been wanting to build a CNC for a long while.
I've tried one last year, just like the one in this video: https://www.youtube.com/watch?v=zgbCy2tQg9Y but had a lot of problems with jagged movement.
This week I decided to scavange all parts I had laying around and start a new build with a clear objective: Build the cheapiest CNC possible that can accurately cut a foam sheet (Since I'm from Brazil I can only get Depron, which comes in 680 x 1000mm). It alse has to be portable and somewhat compact since I have to put it away when not using. I was wondering how to build it without investing in linear guides/wooden frame when it hit me, if there is one thing I'm good at is building with foamboard (Lots of plane crashes, hehe).
The idea is to use foambord for the frame structure, drawer sliders for linear guides and a hot soldering iron (With a modified tip) for cutting depron. The drawer slides are detachable, so it makes it kind of compact to store under my bed.
The system is run by an arduino board (This is the only part that did work well last time). For now I'm stuck with threaded rods for movement, but I'm ordering some timing belts from china to upgrade it afterwards (It is impressive how expensive the belts are in Brazil, I bought 10m + pulleys for the same price I would pay for 2m here).
So this is how far I got this week. I can only work on it on fridays so it may take a while to finish it but if you have any suggestions feel free to make it!
For the frame, I've build 50x50mm blocks. X axis is made from 2 block per side, adding up to 1.2m. Y axis is made from 1 block per side being 0.7m long. This will give me 1.1m x 0.6m of working area (A little less after I figure out how to install the soldering iron, which I'll use balsa in order to not melt the frame).
Blocks have internal square "braces" for extra strength, and are built using A and B style folds. They turned out very strong and lightweight.
Blocks have interlocking ends, the X axis blocks can be joined and the Y axis lateral block can also be joined.
Lastly I've laid out the drawer slides to see how it would look and it looks pretty good to me. I still gotta buy 2 more slides to complete the X axis movement of 1.2m
The Z axis is still under development in my head. I believe I'll use balsa+foam as guides, since I'm looking at 20mm of movement at most. I have a spare set of drawer slides for this, but they are 200mm long, which I believe is overkill for what I need.
I guess that's all for now. I'll update the post with new pictures next friday and if everything goes well I'll be on vacations after that so I can speed up the build.
