Radian build - will it work ?
Just throwing this out there to the group - very provisional drawing board exercise so far - could this work ?
I've reduced the TT wing chord and lost the 'spar' but chord/span proportion (aspect ratio?) is still not as per as the actual Radian - im assuming the weight/lift ratio (!?) will be not be scalable using DTFB if that makes sense - i.e. its heavier so need a bit more wing surface. Sorry I really dont know much about this stuff!
This is 950mm (37.5") span - so kind of a 50% full size Radian - running mighty mini power unit (pod is slimmed down a bit) I have "lift doesn't always scale down" in my head and i guess weight might be a problem overall....
Not sure if the electronics would fit - or how access would work. Also the tail feathers / push rod routing is tricky.
Surprised how little elevator surface there is on the Radian - is this to do with the short fuse to counteract pitchy ness ?
Anyway - comment and ideas welcome on this.
