Heya, so I've been flying prebuilts for a while and they were a lot of fun. So I thought I'd take a cheap nose dive into building my own. I purchased the Electrohub, the naze32 acro board, and the power pack that was suggested for it. Figured if I wanted to delve deeper, I'd do that on my next quad. I did buy the angle brackets and I kind of suspect that those might be my problem currently. ANyway.
Assembly was fairly easy, some soddering was a bit scary, but all in all it went together well from what I can see. I set it up with my laptop, made sure the receiver works right [and it does,] calibrated the ESC's, made sure all the settings were correct according to FT's video on the Naze 32 board. I take it out to test fly and in manual mode hovering, the entire thing wobbles. Left and Right is appears, not really forwards and backwards. Now, I can fly it around just a little bit this way, and keep it under control. This is fine. If I swap into Horizon or Angle mode, the thing wobbles hard until it eventually flips over. Thankfully i've only done that once, and at low altitude to avoid any real damage.
So, more specifics?
I built it as a quad, and I did set it up in deadcat style. Because of this, I have moved the Naze32 back on the quad a bit to account for center of gravity [maybe that's the issue? FT's videos said to do that.]
I also bought the angle arm brackets, because I really wanted a stable and possible video copter later once I eventually build my 250 racer. Now, there weren't any great examples of how to actually use the brackets, I did make use of it to the best of my abilities but I couldn't really figure out how to make it square. [I do have 4 other sticks, so I'm seriously considering tossing the angle brackets and just using straight arms. Maybe that's my problem? It's kinda what I'm guessing right now.]
I didn't adjust anything in PID tab, I left it alone. However I tried switching between a few of the options there? [MultiWii old, new, and 2.3?] and honestly I didn't see any of the settings changed at all between those. So I wasn't sure what that meant.
I found it really hard to get a good place to put a battery under this thing. I'm considering building my own kinda strap for that. The battery literally only hangs on the back two holes of the electro hub. I can't fit another strap on there to center it more.
So right, any help or suggestions would be nice! I do feel kind of stuck at this point. Thanks =D
So, more specifics?
