Looking great on the covering and the build!
The Cuda is a great choice for a first balsa build for experienced pilots. For lots of fun go vertical, full throttle and aileron, and see if you can count how many spins she does before you lose sight of her! Then cut the throttle and after the stall, give it a little bit of up elevator and side aileron and she'll start doing big circles so you can figure out orientation again. I love mine, but she is a full adrenaline rush and landing with shaking hands is not uncommon.
Now that you're thoroughly hooked on building balsa, check out the list of kit manufacturers over here to help out with that important "next kit" decision
https://forum.flitetest.com/index.php?threads/balsa-kit-manufacturers.35042/
In particular, and with the larger size you're looking for, check out
http://oldschoolmodels.com/sr40.htm she's got a 60" wingspan and is a solid fun fly airplane that does everything well - flight characteristics similar to an Ugly Stick.
There are also tons of great kit options through
http://manzanolaser.com/ of all sizes, and if you've got a warbird itch this is a good place to scratch it. A fellow club member and I both have I-16 Rata builds from Manzano in the works and the kits are very good quality.
