bpw823
Junior Mastermind
Hey everyone,
Just another project I've been working on the past few months. I've been refraining from posting anything because projects often get put aside for schoolwork, but this one's definitely coming together shortly.
I found myself designing a 60" divebomber in AutoCAD in December, and I put it together slowly afterschool everyday since. Recently I've got electronics going into the wings, and half of them are sheeted with foamboard already.
I use the school laser cutter to cut out the fuselage formers. Now, the cutting bed is 2" too short for readiboard,
so I cut 2" strips off of the sheets each time I use the laser. This leaves me with a ton of scrap foam strips,
and I decided to use these strips to line the fuselage. Stripping them of the paper allowed them to mold with the fuselage's curves, and will only require minimal fill and sanding to smooth and finish.
The wing has been interesting to figure out. I plan on adding fully-functioning airbrakes,
so determining the geometry of fitting all of the inner components has been a challenge.
I believe I've found a solution and will build the system once I get hinges for the control surfaces.
Electronics are on-hand and ready to integrate as soon as they're needed. It's been pretty smooth work up to this point.
Next step is the completion of the wings and engine/motor mount. I have the CAD drawing ready- I just need to get time to cut out the pieces. It's been a long FIRST Robotics weekend at DCMP so it'll be a good refresher back in school tomorrow.
More to come soon!
More to come soon!
