Headed to the oval for a test fly this morning. There was a bit of dew on the grass, and this grass is more your playing field type stuff - smaller blades of grass and a little softer. I thought that if I couldn't get it to ROG (or is that DOG) on the grass then I could use the astroturf cricket pitch, and if that didn't work I'd give it a good hard chuck.
Plan A worked, however, and I was surprised at how well the rudder tracked it. Much smoother than the tail draggers or even the tri-wheel planes I've flown. About half way across the oval, it took off by itself. Needless to say it needed a bit of down trim, but not a crazy amount. I also needed a little trim on the ailerons.
The roll rate is nice enough for a big glider - better than the Bixler. The polyhedral isn't as effective as the Bixler or AXN's but it gets there in the end. I haven't installed flaps yet, but it can get down fairly slow without stalling. The wing chord isn't as wide as the Bixler and I found the glide slope to be more similar to the AXN. On the topic of the wing, I didn't see any flexing or bumping on any of the low, fast passes I did.
After some mixed throttle flying, I landed and felt the motor and ESC. The ESC was barely warm, but the motor had a little bit of heat. Landing is much like other gliders - it just keeps going and going. I used the technique of putting it off into the distance at the other side of the oval, cutting the power, turning back toward the oval and pushing the nose down until the plane's about 1-2 metres above the ground. The ground effect and speed keep the plane low and stable and it eventually touches down and slides in at my feet.
All up I'm really really happy with this plane. I think it's a new favourite and I can't wait to stick some FPV gear on it. With a 5000mAh battery, it balances nicely and wing loading feels pretty low. The additional drag of a camera and cl antenna probably won't be felt in the scheme of things. One slightly annoying thing is the motor angle. When you trim it to level at half throttle, going to full throttle makes it climb a little more than I wanted and speed bottoms out - top speed is at just over half throttle. I guess it doesn't matter too much, but I'll have to watch my altitude when flying FPV. I already have a tendency to fly higher than I should with the Bixler, which only climbs marginally on full throttle without stick input.
