yeah I think thats true for any company....how is there customer service/warranty? If I get a dud, can I get it replaced?
Hmm, don't know... All my stuff works. Sorry I can't be more helpful.
Okay I updated to 2.0.3 and my FLVSS and GPS just showed up in the mail. Can anyone point me to the best way to set up my FLVSS to alert me when a cell drops below 3.5 and how to configure the GPS to speak my speed when I toggle SH?
I've created a "new file" in Companion2 to create some defaults that I want to import into other models like your battery low settings, safety switches, etc.
But I have problems changing the values in the Logical Switches. If I enter a number like "3,74" it gets rounded down to "3,00".
Is that a bug in my OSX version or perhaps an internationalization issue? (I can't enter 3.74 either though).
Okay, now that I'm home I checked my radio and I forgot that the battery setup I posted last is a little off... So from my radio this is what I use.
Now the custom functions that you can use should be this...
But like I mentioned before the speed function I can not test. You will have to test it yourself. The other two will work for Audio warning for the battery.
The GPS sensor probably takes a few minutes to find its satellites when you first boot it up. When it's new it has to find your "general area" first which I think it remembers the next time it is powered up. So if you fly in the same area it should be find satellites fairly fast then.
@robschonk: Thanks. I did not find an open ticket for that, so I reported it anyway.
At one point when I was thinking about Taranis I noticed someone posted a link or .bmp artwork for Flite Test planes that can be uploaded. Now that I have a Taranis I can't find the link or artwork. Anyone know where it is?
Hey guys I have a question. I have a timer set to start after I engage throttle and then it calls out each minute. Can I have it call out my cell voltage each minute from throttle engage also? I have the FLVS set up right now to call out when I use SH and also when a cell drops below 3.4 it will tell me battery critical and then every 3 seconds announce my voltage. This works fine but I like the idea of mid flight updates without haven't to flip SH.
That would be great, Kurt. I can get it to repeat every minute but I can't figure out how to make the minutes start once I activate my throttle.
Just got my Taranis... I LOVE this thing! Why would you buy anything else? Seriously?!
Question: I have an XJT external module that I have been using in my 9XR. Is the internal Taranis module basically the same thing as the external XJT? Is my XJT module redundant to me?
