PenguinWings
Hello benevolent Forum Members!
I just got finished soldering up an FT Gremlin, but would someone please help me out with the Betaflight setup? It's being uncooperative...
I'm using a Frsky XM receiver, so when I configure the receiver in Betaflight, I choose 'Serial Based Receiver' and 'SBUS' before clicking 'Save and Reboot.' However, when I come back to this tab after disconnecting and reconnecting, I find that the setting has been reset to 'Spectrum 1024' instead of SBUS.
Naturally, the receiver tab shows no colored bars since the FC is set for the wrong protocol. But here's where it gets weird: If I look at the Receivers tab first, and then go back to the Configuration tab, the protocol shows up as SBUS, like its supposed to, although I still don't see any colored bars on the Receivers tab.
So I guess this is the issue: I can't get SBUS to stick!
I'm using a Taranis QX7, if that helps, running Betaflight 3.2.1 (and I tried 3.1.3) on Windows 10.
Also, I'm pretty new to the actual building aspect - my soldering is pretty bad, but I don't think that's the issue as the board boots up ok.
Thanks!
PenguinWings
_
Thanks!
PenguinWings
_
