The FT Bloody Wonder - Scratch Build
This Flite Test scratch build airplane was inspired by Bloody Mick's FUNBAT and the Sig Wonder. The FT Bloody Wonder is the newest addition to the Flite Test Swappable Series! A series of scratch built planes designed with an interchangeable fuselage.
FT Bloody Wonder Build Plans Available Here:
View attachment FT Bloody Wonder - Swappable - 2 of 2.pdf
View attachment FT Bloody Wonder Swappable - 1 of 2.pdf
TIP for printing the plans:
To print "tiled" use Adobe Reader X and in the print dialog select "POSTER", select "Cut Marks" and make sure "Tile Scale" is 100%. Then overlap and tape as required (after trimming the top overlapping edge).
(Thanks youtuber larrybarrick for this suggestion!)
Detailed build video for the power pod (fuselage) available here:
http://youtu.be/aMeGqVGZcjA?t=2m11s
Equipment used/recommended for this build:
ADAMS Foam Board
Turnigy TG9e 9g Servos
Push Rods: 1.4mm Piano Wire
Linkage Stopper "Speed Clevis"
NTM Prop Drive Series 28-26A 1200kv / 250w
TURNIGY Plush 25amp Speed Controller
Turnigy 1300mAh 4S 20C Lipo Pack
Futaba T8FG Super 14ch Transmitter w/R6208SB 2.4GHz Receiver
Futaba R6106HFC 2.4GHz FASST Mid Range 6Ch Rx
Additional/Alternate components:
Suppo 2208/14 1450kv Brushless Motor (Park 370 equiv.)
APC-style Electric Propeller - 8x4E
Suppo 18A Brushless ESC
Suppo SP-90 9g Micro Servo
The FT Bloody Wonder features a swappable fuselage that is interchangeable with the other airplanes in the Swappable Series!
This combat flyer is capable of vertical take off, it can fly off the 24gram motor setup on previous swappable fuselage or you can upgrade to the NTM Prop Drive Series 28-26A 1200kv / 250w motor.
One of the unique designs of this scratch build is the rounded aileron wing design. Created the same way that the Baby Blender wings are made, the rounded ailerons provide great lift!
In case you missed the review of this plane you can check it out here:
http://flitetest.com/articles/Vertical_Drag_Race_Combat
The Flite Test Swappable Series currently consists of:
The Nutball, The FT Flyer, Delta Wing, Baby Blender
