Started my MMustang build. Did most of the gluing using the 3M77. I did have some issues with the foam deforming on my wingsI did spray onto the paper first, then waited a bit, then put it down on the foam. I'm guessing I didn't wait long enough or I used too much. I waited probably 20-30 seconds. It was pretty cold in the garage so I might have rushed it. Anyone else experience this? Any suggestions? Most of the smaller pieces are find. I'm thinking I'll head to staples for another print and try it again. Any input is appreciated.
You're using way too much glue. At that point of saturation you start gaining weight in addition to melting things. I'very done a bunch of playing with 3M 77, and you probably need to use a third of what you did.
