Looks great!
I've been dying to get mine out again, was busy last weekend and didn't get to fly anything at all. Heard my LHS finally got more piano wire in this week so I stopped in to get some (and they finally had thicker wire in stock so I could replace the weak coat hanger gear on my other FT planes!) But as tends to happen I couldn't leave with just what I came in for and ended up picking up a nice red spinner for my Spitfire as well.
So I was REALLY itching to get her in the air this weekend. Woke up early yesterday...and was greeted to the windiest day in over a month
Way too windy to pop her in the air. But that's why there are two days in a weekend right? Right! Woke up early again today and it was totally calm out.
Ran up to the field, and tossed the FT Flyer in the air to feel things out - and found the gremlins were in abundance today. Something very funky was going on - almost like I was loosing signal but I wasn't that far away and the control surfaces were still responding (but then sometimes the control surfaces would stop responding but the motor would still throttle back up.) Weird. (I had to repair one of my RX's when the antenna pulled off - I suspect it was on this one so that may explain it.)
Oh well. Air was still calm though and I didn't want to risk loosing that so I pulled out the Spitfire. Man she looks good with that spinner. For some reason I couldn't get my 2200mah battery to fit today...it fit before but today it wouldn't clear the wing. Grrr. Oh well, got some 1500 packs and that fit so no biggie. Got it balanced and up in the air...and oh hello Mr. wind I see you decided to join me today. Made a few circuits of the field and started having a bit of fun. Roll rate still seems slow on mine for some reason so I thought I'd bring it in and check things out...nice slow approach into the increasingly strong wind...moving right about walking speed but super stable in the air and looking great. About 4' off the ground and...WHAM big gust of wind. Like a giant invisible hand came out of nowhere and pushed it to the ground. Didn't nose in, just a hard belly flop. And again the front wing mount tore out. Not in the same place it tore out on me last time...but same basic damage. The repair held but with more damage next to it now I'm definitely going to just build a new fuselage at this point. May go solid wing next time...that front mount just seems to tear out way too easy for me.
Not to go too far off topic but figured I'd toss the bloody wonder up since the wind was still not TOO bad. Whoops, turns out the popsicle sticks I added inside my "big pod" to reinforce the rear support holes now make it not fit the BW. Well, almost not fit...a but of squeezing and it got in there (it's just foam after all!) BW flew well, but the wind just kept getting worse and with no rudder I wasn't having much fun with the wind pushing me around. Brought it in for a landing...nice and slow stable and level, power off a few feet above the ground - hey look my prop is even horizontal this time...soft gentle landing. But sure enough some how even with a soft slow landing and the prop horizontal I managed to break it. I seriously can't fly the BW without going through a prop each flight for some reason!
At this point the wind was enough it was kind of tough to carry the BW back to my truck so I loaded up and called it a day. Not nearly as much flying as I had hoped to...and the Spitfire having such a short and unhappy flight was a major disappointment. But even a disappointing day of flying beats a day of no flying so I'm still smiling
Now to cut out a new spitfire fuselage and see if I can't figure out a way to reinforce that front wing mount while still leaving room for the 2200 up there....hmm....
