The two air scoops behind the cockpit are covering the flush mounted servos for the elevator and rudder.
Above and beyond... You do excellent work. It is simply beautiful to look at.
I run into this a LOT, (my laser's working area is 500x700mm) the Mustang for example, I had to split the fuselage into two pieces... (and don't get me started on Spars!)FT's plan's are 3 pages, mine are 5.
On a side note, the Phantom is looking really sweet!On that note, I think I am done for the night, but I start the build tomorrow.
Thanks brother, she is pretty much ready for Minwax and paint. That's why progress has stalled on that build. I really don't have the place to do that at home. I will take it to work with me one of these days we don't have a lot going on.On a side note, the Phantom is looking really sweet!
There can be more waste with laser cutting, but I can't imagine printing the plans, taping, transfering to the foam then cutting... I have real respect/sympathy for those of you who have to go through that!
How do they charge you? Time on tube/machine?
One trick I did with the explorer wing (which is massive BTW) was to cut a "negative" template for the wing tips. Cut the pieces out to what I could (max of laser limits) then trace the wingtips out using the template. Worked pretty good. (If this doesn't make sense let me know... I'll see if I can take couple pics.) I expect the same issue with the founder's plane (using full width of the foam sheet.)next time i think i will chop off the nose instead.
