These are not long range quads mate. They fly great and do well in a lot of conditions but they weigh nothing and if winds are over 10mph you really need to have it tuned great or be really good on the sticks. Besides trying to find these buried in the front lawn if you didnt mow this week can be a challenge lest alone having to travel any real distance to find it.
Depending how nuts you fly.. Ill say you can look for 6 to 9 minutes of just cruising or under a minute and a half ripping around like a wild man. I have videos with 12 to 14 minutes powered on time with 3s 450mah packs. Thats flight time and walk time to and from crashes. Again the Turbo kit has more power so that will vary as well. 50mw is my normal on mine as I just run dipole on both the quad and goggles for that.
The inverted motors on the rear is to save bent shaft damage from tumbling it across the ground as I beat the bajeebus outta that bugger and it just looks at me like.. "Lets do that again!!!" Probably why its still all OG parts baring one esc that got wet and let the magic smoke out cause I flew too early and the dew was heavy that morning.
As for the Red. That is simply Testors model paint over super glue I run around fame edges. I use it on all my frames.
I also use metallic green and purple as well on some builds. In fact the 2nd pic above is now in green.
