So I recently put together one of my first speed-build kits from flite test, an FT Viggen. I was super excited to get it in the air using the 70mm edf setup from Grayson hobbies. When I finally got out to a field by my house to fly it, I ended up crashing and wrecking the airframe on takeoff. Shortly after takeoff, my Viggen rolled twice to the right, then spiked into the ground. When I reached it, I found that the edf had seperated form the mounts, and I assumed that this was what caused the problem. So I rebuilt the plane from scratch (with the same electronics) and got back out to the field, only to have it perform another uncommanded roll and crash on takeoff, however this time the mounts and airframe were still intact. I was wondering if anyone else has had this kind of problem and how I might be able to fix it (I couldn't find anything like this anywhere not the forums). By the way, my transmitter is the fs-t6 from fly-sky.
