It looks awesome!
When I did the CG calculations for the FW-42 I just maidened, I did it first with a 5% static margin, and then again with a 15% margin and drew the resulting 3/4" range on the plane. Here are the calcs I used;
After glide testing the best spot was in that range at about 2/3 of the way towards the nose - so maybe a 7% margin. On the maiden flight that turned out to be perfect for very stable performance - I'll probably want to shift the CG back a 1/2" for more aerobatic flight and will test that out this weekend.
The only other thing I can say about the CG is make sure to do glide testing before powered testing. If it doesn't have a smooth trajectory when it's tossed into high grass, adding power won't make things more stable. :black_eyed:
