Coming back to this, it was time to add the formers and covers. I started of by placing all the formers into their slots to make sure that they fit properly and that no design mistake were made. Guess what, a few design mistakes showed up, fixed them, re-printed the parts and cut them out again. Once done I had to decided what to start covering first so that I would be able to work on the rest of the plane with easy as the build moves along.
I decided to start with the front top section of the plane that way I would still have the ability to place it flat on the edge of the table. I started looking at the canopy and the round piece around the nose and saw another problem. The front wing holder seemed to be getting weaker so I cut up a 1cm table using an a fold and glued it in place.
I then placed the front former for the fuselage in place its also acts as the bas of the powerpod. The former didn't line up properly with side slots that I created to help keep things line up, so I closed them up with the cut outs from the former and fix the plans accordingly.
It was now time to mold the foam into place I tried doing so without removing the paper from the inside thinking that the gap isn't that big and can be bridged easily. I was wrong! so I removed the paper from the inside. I later removed more paper to allow this entire part of the nose section of the fuselage mold and twist into place. The gap was too wide and tall that it didn't mold easily so I removed off some of the foam to make it easier. At this point I tested another former that I had wanted to use to help hold down the foam cover. I ended not using it because it didn't help much, and was actually making it harder for me to place the foam covers with it.
I finished molding the fuselage sides into place and glued them down. Then I started working on rounded nose part and the canopy windows, and it didn't go well like the rest seemed too. I say seem to because looking back also there I had to fix, change, and do it over, but that was a breaking point in the project for me. I was annoyed and frustrated, willing to give up. Thinking maybe to skip this part and get back too it later, knowing that it will be harder to do that. I would plan a piece, cut it out, and test it; just to realize that it was far from even being OK. I advice with some friends on the forum (
@Splinter189 and
@Hai-Lee) who both gave me some great tips, that gave me some encouragement to keep trying. That's when I made peace with making cover parts!!! No the pieces I design don't fit perfectly off the bat but I found a way to make it less annoying, much faster and actually quite fun
. I would design a piece, print it out and cut it with scissors on the lines, then I would try it on the plane and see what I need to change. It's not a fast process but less annoying than testing with foam. Once you are happy with the pieces and how the fit on the plane you can cut them out of foam and test them.
So I got myself some covers designed dry tested with paper a few times and was ready for the real thing. I printed out the plans one more time and converted them into foam pieces. I then did a final dry test after which I molded the pieces into place and glued the pieces into place.
I wasn't sure how to place the canopy window so I started playing around with it to see how it looks. The front window needed some bevel cutting to allow it to sit better.
I still had to plane the side part of the canopy window and starting planning it out and that's when I thought of doing it as one piece. I went back to AI and started getting the window piece created, 20 mins later I had it
As you can see there is a gap between the canopy window and the side, so I designed a change to the fuselage piece and tested it out, and it seem to be in the right direction. There still was some changing that needed to be done and somethings that I still need to decide on. One thing that I decided to do is make the entire canopy window one piece it's already designed and was tested. It became late and after a week of not feeling well and going to work this morning I had to work, so I decided to take a break and do some tests and pictures of the work so far, enjoy.
Testing size to plan.
Pictures of the plane so far, even pulled out the wing to test with
Not too happy with the canopy window though, it seems to far out. In the pictures I'll looked at yesterday it seemed to be out a lot might have been mistaken. Nevermind this is V1 which will take a beating anyhow, V2 will be the real beautiful beast
. That's it for now, back to AI for more parts
