PlanesGuy888
Airplane crasher
For the FTFC20 build challenge, I decided that I would like to participate this year with an aircraft of my own. I chose the Spitfire Mk.I because it has always been a favorite of mine and I have always loved the look. This Spitfire is not going to be a normal FT Spitfire though. It has been designed for indoor flight, in a similar manner to joker24458's Bf-109. For years I have admired the look and flight characteristics of joker24458's Bf-109, and I finally decided that I am at a point where I could try to design my own. I have been working on these plans for a month or two now and I decided that since they met the FTFC20 Build Challenge requirements, I might as well enter them. I started drawing the Spitfire off of these AeroFred plans: https://aerofred.com/details.php?image_id=91058
The Slo-Fly Spit, as I have nicknamed it, is intended to run off of an FT B-sized power pack. It will use six 5 or 9-gram servos, and a 2s 1000mah LiPo. All of the foam is de-papered, to save weight and to aid in the forming of the fuselage skins.
The plans are currently not finished, but I have started construction. I have started on the wings. I printed out the wing templates and cut them out.
The next step is to roll the wing on the edge of the table to curve it. This is similar to how the FT Master Series is done, but the wing is de-papered and is much more prone to cracking. The wing is going to be a single surface under cambered airfoil to have high lift/high drag, which is good for slow flight.
Next, I glued in the inboard 3 ribs to the wing skin. It is important to take your time because the wing skin does not like to bend to the ribs. The first 2 ribs went on fine but the third gave me trouble.
Before I glued on the 4th and 5th ribs, I cut out the aileron. Then I beveled the upper surface and made a tape hinge on the bottom. I made sure to reinforce the hinge with hot glue, and it helped it's strength a lot.
That's all for today, hopefully more updates will follow soon!
