Hi all,
Here's my most recent quarantine build while I'm back home with nothing else to do: A full VTOL capable foamy F-35
Specs:
Wingspan: 36"
Length: 44"
Weight: ~900 grams? (haven't weighed since I painted it)
Flight controller: teensy 4.0 and mpu6050, custom software
Motors: lumenier rx2204 2300kv
ESC: lumenier 35a 4-in-1
Battery: 1500mah 4s 40c
Yaw tilt servo is just an sg-90 along with the elevons. Flap tilt servos are standard size spektrum. Flight time is about 5 minutes assuming half of that is in hover. Airframe is a 10mm poplar skeleton with 9mm EPP foam. Some 3mm carbon tube in key areas for additional support
Two rear motors are directly mounted to the flaps "airhogs" style. These flaps actuate down for hover along with the front lift fan, and are fixed in forward flight:
Pre-electronics and paint:
Undercarriage:
Custom flight controller setup:
View attachment
And with paint!
CG is a little forward toward the front lift fan, so that motor is working a little harder in hover--I'm looking to upgrade that motor to something a little bigger. My 'intermediate' flight mode just consists of actuating those flaps to about 45 degrees so it can pick up some forward speed. Forward flight is just elevon control and the front fan cuts off (shown in the first video which is why it pitches down going into forward flight, I have since updated the code to fade the front motor out and am waiting on a flight video of that).
One more video of early indoor hover testing:
Any other VTOLs here? Happy to answer any questions, or nerd out about other cool VTOL platforms
Cheers
Specs:
Wingspan: 36"
Length: 44"
Undercarriage:
View attachment
And with paint!
Cheers
