billyshaw22
Little update, started the wing build but ribs are temporary until I get all the alignment right.
Thanks!Looking great!
Building the motor boxes, I used 1/8 ply to the spar and epoxied everything in, I used 1/4 ply for the firewall, i epoxied that in and I plan on pinning the sides to the firewall with 1/8” round hardwood pegs. I am also planning on running hardwood supports on the rear side of the firewall to the sides for more strength.
Are you removing the plastic film/coating that comes on this foam? If not, are you doing anything to help the glue adhere through it?This is what the stack looks like
after everything is built, I will remove the plastic, I only leave it on to help keep from hanger rash. I don't leave any plastic on the internal parts of the plane or at the glue joint. I found that if you leave it on and glue to it, it will peel off at some point.Are you removing the plastic film/coating that comes on this foam? If not, are you doing anything to help the glue adhere through it?
