I finished it! Started on Oct 1rst, 2018 and finished Sept 8th, 2019, so about 11 months, but I moved in the middle of all this so that really slowed things down. I just need to do some motor testing and measure the Watts with a watt meter, then set up control surface throws and trims, set up weight and balance, ect, ect...The AUP (all up weight, flight ready with battery) is 4,100 grams (9.039 lbs). So, that is a little on the heavy side, but this is a conversion and many reinforcement mods were made to accomidate the extra weight. You may see some white around the canopy as the glue is still curing. Were probably looking at a maiden flight in a few weeks as I now have many other projects for the house in progress.
I also change the Red Bull color scheme a bit...artist's license.
