I have 8' ceilings in my basement shop so this seemed like a good place to get my models up off of every horizontal surface.
Home Depot Parts List
(All 1/2" PVC - get the cheapest you can find)
4 Elbows
2 Endcaps
1 Tee
1 Drop Ear Elbow
2' Tubing
10" Pipe Insulation
All of the fittings are around $.30 each
The tubing is around $2 for 10'
The Insulation is around $2.5 for 12'
Total out of pocket is $7, but you have lots of extra tubing and insulation.
You can easily make at least 3 more depending on the sizes you need for just $2.50 each for fittings.
I won't give any dimensions - each plane is unique.
Additionally you can have them hang higher or lower if you want to hang them at different levels
to pack them more densely.
The insulation will keep the pipe from denting or marking your EPO birds.
Tools
PVC Tubing Cutter (highly recommended)
PVC Cleaner
PVC Glue
(you'll also need a screw driver and some screws to attach it when it's completed)
I can make one in around 15 minutes if I don't have to fiddle measuring too much
I've also made some other styles like for my Radian where I have 2 'shelves',
one that holds the fuselage and one for the wings.
Best regards,
PCH
