ok so i should just keep focusing on the ACC trim then, and Dan you lost me on the topic of SLmix , stick centered and edge and all that. sorry man im completely new at this. And like i said im just meathead getting into quads and this technical stuff. wat do u mean by stick is centered or at the edge. wht do u recomend i keep the POS 1 on Normal SL?
Think of it this way, the acro mode is singing one song to your ESCs while the SL is singing another. The mix mode literally mixes these two songs depending on where the aileron/elevator stick is positioned.
When you let go off the stick, the springs pull it to center, and in the mix mode will only let the ESCs hear the SL song. Move the stick to the outside edge, and now the ESCs only hear the acro song. It's a smooth transition between those two, but the high/medium /low change how it transitions between the two songs. .
High begins transitioning to the acro song almost as soon as it comes off center and will move to full acro very quickly. Release the stick, and it will more slowly move the song back to SL.
Low will let you move the stick a little bit off center before starting the transition, then slowly switch between songs as you move outward. Unlike high which would be fully acro by mid stick, low needs to go almost full stick before the self level song is no longer heard. Release the stick, and it quickly returns to full self level.
Medium, of course, is somewhere in the middle.
Play with it a bit when you get a chance, starting low, and you'll see it acts a lot more stable than acro, but far more agile than SL, and almost identical to SL if you keep the stick close to center.
