Hello People.
I'm having some troubles with my Bonsai wing. Let me explain my current setup first:
My first toughs ware low weight and cheap. so thats why I bought 9g servos instead of 5g or even lower. because they are more expensive than the 9g @ the Hobbyking EU warehouse. For the rest I bought an 3ch hobbyking receiver to fit my Turnigy 9x TX and save some grams because the 9x RX is heavier than the 3ch GT-2.
This all does the job, but I did not open this topic just to say my setup is working.
Maybe you already guessed but yes this setup is pretty slow.
This Turnigy 1811 2900Kv is a great little bugger, but it's simply not powerful enough. at least not with an 5x5 prop on it. 6x3 or 6x5 are a little bit to big for this motor. And after all these wires are so tiny and stiff that they keeps cracking and disconnecting from the 2mm plus no matter what I do. I use some Shrink tube to get them more secure but I don't know for how long it will last.
And because I've flown my wing for several hours and days i really like something faster now. I've got some other planes to fit my needs. but I want to upgrade this little bonsai to get the job done. So giving me advise about another plane is kind and appreciated, but this is not why I opened this topic.
I need to find some motor that need less than 10Ampaires, because I'm currently limited to my 10Ampaire ESC and I don't want to waste that little thing if it can be useful. I've got several 3cell lipos here so that wont be an problem.
I've found some possible candidates both with 2mm plus that fit my 2mm plugs on my ESC:
Timeless
Ps. I also asked this question on RC Groups. but I want to get multiple opinions. so thats why i double posted the same question on multiple forums.
- Hobby King GT-2 2.4Ghz Receiver 3Ch
- Hobbyking Bonsai EPP Wing 600mm (ARF)
- Turnigy 1811 brushless Outrunner 2900kv
- Turnigy nano-tech 460mah 2S 25~40C Lipo Pack
- APC Style Propeller 5x5 (2 pc)
- Robbe ROXXY BL CONTROL 710 ESC (10amp)
- Turnigy TG9e 9g / 1.5kg / 0.10sec Eco Micro Servo (2 pc)
Turnigy Aerodrive SK3 - 2122-2100kv Brushless Outrunner Motor (EU warehouse)- Turnigy Aerodrive SK3 - 2118-3100kv Brushless Outrunner Motor (EU warehouse)
- What is for the bonsai a better motor? Higher [KV] or Higher [P], Less [P] will give me a longer flight time. but will it go as fast?
- maybe there are some better motors available from the EU warehouse that will fit my needs?
Timeless
