marcotheboy
I thought I would try to see if the FT Spitfire plans translated to 6mm depron and scaled down to fit the mini power pod and a 2S battery.
Here is the result (next to the regular size FT Mustang):
It has a 2204 2300kv motor with a 5x4.5x3 prop (although I found it flies better with a 5x4 2-blade prop).
2S 1500mAh LiPo (80 grams).
4 x 5g servos.
Total weight (incl. battery): 260 grams
Here is the test (maiden) flight:
(It was quite tail-heavy)
If anyone is interested, I can post the pdf plans (note: the plans fit 6mm depron only - not foam board)
4 x 5g servos.
