I've got a 25cc Engine. What should I put it on?
Just as the title states I've got a 25cc from a leaf blower and want to put it on an rc airplane.
Hoping to use around a 22x10 propeller.
Any ideas are helpful!
Man.
P.S. Does hot HAVE to be Flite Test, could be rc plans .com or nerdnic or 13th squadron, or really anything as long as it doesn't put a virus in my computer.:p
Insanely Addicted Techno Geek
Why such a big prop? That motor was designed for high RPM and a small impeller and is not optimised for such a big prop.
I'm somewhat limited as far as building materials basically: Foamboard, coroplast, dowels, whatever's cheap except balsa.
Could do a ( not so ) slow stick but it's gonna be full sheet size foamboard wings. Figure perhaps +20 ish pounds of thrust but whatever it is, it needs to be big and STRONG
Hmmm square plastic gutter drain for the fuselage, 4 sheets of foamboard for the wings, 1/2 inch plywood spar, another couple for the tail feathers.......
Another hmmm, the prop.will be more expensive than the plane
Never mind I just figured it out, It was just an old link.
I just had to go to spad's website and find it there. Simple!
Thanks Draftman1!
Now I won't be building this plane for a little while so if anyone thinks they know of a better one, feel free to post it in this thread.
Also, Not sure on prop size yet.
Just found this Flite Test Video, Might be a good candidate for a 25cc.🤔 Anyways it looks cool.:cool:
Im fond of either liquid nails construction or RTV silicone for coroplast, with a tape cover on the outside joints. Some times you still end up with the "bag of balsa" mode after a crash.
