Finally getting back to work on this one. All the parts have finally been finished sanded and given at least 2 coats of WBPU.
All the surfaces were hinged using DuBro (Blenderm) hinge tape.
For the aileron servis, I thought I would try something new. I do not like the look of servos hanging out of the airframe. So I cut small panels that the servos have been glued to. Then I lined the ends of the openings with a small strip of foam to catch the servo panel.
The servos were centered and the arms screwed on. They are offset slightly forward to give me a little bit of aileron differential.
Finally the wires were chased through the wing and the panels were glued in place using clear (non-foaming) gorilla glue. A little bit of extra work, but a far cleaner look.
