SauSAliens
Is there a way to set both gear and flaps to one channel without using a y connector? I was under the impression you had to have an unused channel for the safe function. I was also under the assumption binding via safe procedure would auto enable safe without using a switch.Huh? A DX6e should be able to handle the plane you have with switches to spare. Where did the need for a Y connector come from?
