Paracodespoder
One thing to note here, Mac’s can’t use adobe unless you buy a computer program, which is a little pricey.Thanks!
You can print the full size plans on regular sheets of paper if you use Adobe Reader. All you have to do is open up the plans in Adobe Reader and select print. After the print window opens up there should be a section in the middle of the window labeled "Page Sizing & Handling" right below that there should be options to choose between "Size" "Poster" "Multiple" and "Booklet" You are going to want to select the "Poster" option. Next, ensure your tile scale is set to 100%, your overlap is set at 0.005 in. and that you have the "Tile only large pages" option selected. You can also select "Cut marks" which will make taping the sheets of paper together easier, but it will increase your page count from 8 to 12. Lastly, go down to the bottom of the print window and click print.
Note: If you do not have the poster option on your laptop you may need to upgrade to the latest version of Adobe Reader. It may even be old enough that looking in the program options for updates does not work. You will have to go to Adobe website to get new version.
For people with a Mac what do you suggest?
I bring it up because although we have a computer with adobe, it’s super slow to load anything (it can take upwards of 20 minutes just to get it on, download plans and get it to print). If there is a way to tile plans on a Mac that would be super helpful to know what. BTW, I can print regular, tiled plans.
(This is not a complaint, just looking for some options to make printing non-tiled plans easier 😉)
