Mighty Mini MkIII - Build
Baby Baron next to the Mighty Mini MkIII
SPECIFICATIONS
ELECTRONICS
SETTINGS
IMAGES
FLIGHT VIDEO
BUILD LOG
If you think you might make more than one of these planes, you may want to consider making some poster board templates. Complete instructions for making them can be found in my article DIY Poster Board Templates.
More build details coming soon.
MIGHTY MINI MkIII
Mighty Mini Sized Bloody Wonder MkIII
DETAILS
This is my second Mighty Mini sized plane. It uses the same power setup as the FT Mighty Mini series, and can use the same power pod as the Mini Scout and Mini Speedster. Like the Bloody Wonder MkIII, the mini will include the different tail configurations.
PLANS
PLANS
WINGSPAN: | 16.75 in | mm |
LENGTH: | 15 in | mm |
WING AREA: | TBD in2 | dm2 |
WEIGHT (AUW): | TBD oz. | g |
WING LOADING: | TBD oz./ft2 | g/dm2 |
WCL: | TBD | |
CHANNELS: | 3 | |
CONTROLS: | Aileron, Elevator, Throttle |
MOTOR: | Emax MT 1804 |
ESC: | Turnigy Plush 12amp |
BATTERY: | 450-800 mah 2S/3S |
PROPELLER: | 6 X 5 SF (GWS EP 6050) |
SERVOS: | 2 X 5g (hekTronix HXT500) |
SETTINGS
Ailerons : 40% Expo : 50%
Elevator : 40% Expo : 50%
IMAGES
FLIGHT VIDEO
BUILD LOG
Materials
[*=1]1 Sheet Adams Readi-Board
[*=1]1 FT Mighty Mini Firewall
[*=1]3 FT Mighty Mini Control Horns
[*=1]1 BBQ Skewer
[*=1]3 Push Rods 18 GA Music Wire (.040"/1 mm)
[*=1]2 Servos 5 gram (HXT 500 / ES9051)
[*=1]3 Linkage Stoppers (optional)
Tile your plans together and prepare them for transferring to your foam board
