Help! Motor and ESC question
Flyingcollins
I have a 2212-6t motor with a 30a ESC and a 104.5 prop. Does anyone have a recommendation of a speed build kit that would work with that power system.
quorneng
A 10x 4.5 prop is much to big for a 2212-6t. it will likely overload the motor and/or 'fry' the ESC.
Hobby King recommend a 7x4 on a 2s battery or a 5x5 on a 3s.
As the maximum current the motor will draw is 34 A they also recommend a 40A ESC.
With the right prop you might get away with your 30 A ESC but I would not chance it myself.
The FT Scorch would be perfect. The Simple Cub would also work, you would have unlimited vertical.
Bando FPV
The 10 inch prop is a bit big for your power system. Any trainer like plane in the power pack b or c range should do fine.
Brett_N
Way way way WAY Way too much prop for 2200kV - it'll smoke the motor OR the ESC or BOTH within about 30 seconds. Trust me, I know that from experience.
10x4.5 is almost too much for 2212 1400kV motors (ask me how I know that too...)
You want an 8x5 or 8x6 Slo-Fly for that motor. Even down to a 7x6. Either of those in a pusher are a good choice for the Explorer.
I agree with @Brett_N, if it's a 2,200Kv motor, 10" prop is way too much. You will destroy the motor.
If it's a 1,000Kv motor the 10" prop is about right.
Flyingcollins
This is the combo from Wish
